Where did I see the plans for wood frame to hold body while off frame?
Old 03-19-2004, 11:10 AM
Bill Oxley
Bill Oxley's Avatar
Default Where did I see the plans for wood frame to hold body while off frame?
I saw these plans with measurements somewhere, but can't find it now. Can someone send me a link or location?
Tnx,
Old 03-19-2004, 11:22 AM
lilgto
lilgto's Avatar
Default Re: Where did I see the plans for wood frame to hold body while off frame? (Bill Oxley)
You can get it from here: http://vettefinders.com/rhys/resources.cfm
Mike
Old 03-19-2004, 11:51 AM
Bill Oxley
Bill Oxley's Avatar
Default Re: Where did I see the plans for wood frame to hold body while off frame? (lilgto)
Tnx Mike
Old 03-19-2004, 12:07 PM
BigBadRed
BigBadRed's Avatar
Anyone have a better design? It seems like the builder wasn't very impressed.
Old 03-19-2004, 12:20 PM
stpman
stpman's Avatar
Default Re: Where did I see the plans for wood frame to hold body while off frame? (BigBadOrange)
I plan on making one with 2" square tubing they way Dream Car Garage did for the 69 build up.
Steve :steering:
Old 03-19-2004, 04:15 PM
Bob K
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
Support Corvetteforum!
Bob K's Avatar
St. Jude Donor '11-'24
I purchased Nolan Adams body lift video and book. The book has great plans. I built the dolly last year and have not had a problem with it.
Well worth the money. And it supports one of our living knowledge banks! It's nice to give back once in a while.
Bob K.
Old 03-19-2004, 07:08 PM
73Gator
73Gator's Avatar
What ever you do....Make sure that you support the front clip all the way out to the nose.
I didn't! :cry :cry :cry :cry :cry :cry
Old 03-19-2004, 07:13 PM
John 65
John 65's Avatar
Default Re: Where did I see the plans for wood frame to hold body while off frame? (Bob K)
Bob K.
:iagree: I did the same thing with the Adams book and had no problems at all. If i had to do it again I would use stronger and smoother rolling castors. The measurements were very precise and right on the money.Gook luck
Old 03-19-2004, 07:54 PM
Bill Oxley
Bill Oxley's Avatar
Default Re: Where did I see the plans for wood frame to hold body while off frame? (John65,80)
Good advice Bob, where can I get the Nolan Adams info/tape.
And 73Gator, Holy crap, how did that happen? Please post how that "can't happen to me, tnx,
Bill
Old 03-19-2004, 09:12 PM
73Gator
73Gator's Avatar
My original thread is at http://forums.corvetteforum.com/zerothread?id=767208
If you build the VetteFinders dolly, extend the front of the dolly with a couple of 2x4s to support the headlight/nose assembly (i didn't)
Old 03-19-2004, 11:39 PM
R 73 454
R 73 454's Avatar
Make sure the wood is not green, I read somewhere a horror story of a wooden body dolly drying out, doing very bad things to the body... VERY bad things. I'd use the dimensions, then build it from uni-strut or aluminum! :nopity
Old 03-21-2004, 09:33 PM
noskillz
noskillz's Avatar
Default Re: Where did I see the plans for wood frame to hold body while off frame? (73Gator)
I used the Nolan Adams plan as well. The front did NOT extend to the radiator support. Maybe I didn't follow instructions correctly, but if I did it again I would extend the front to the radiator support and leave the support in.
Those vacumm headlights are HEAVY!
Old 03-21-2004, 09:35 PM
noskillz
noskillz's Avatar
Default Re: Where did I see the plans for wood frame to hold body while off frame? (stpman)
That would the the best! Post the plans if you can. A metal dolly that exactly matches you mount point would be ideal. Without that I had to basically rebond everything on the frame to make sure it all lined up. This made it more difficult to reach some of the seams.
Old 03-21-2004, 10:41 PM
Bill Oxley
Bill Oxley's Avatar
tnx for all the help guys! I appreciate it.
Old 03-22-2004, 03:25 AM
Bob K
Bob K's Avatar
Bill,
I don't remember where I got it from, but this site sells it.
http://www.gregsonline.com/eshop/Htm...ideos/NAC3.htm
Bob K.
To Where did I see the plans for wood frame to hold body while off frame?
Quick Reply: Where did I see the plans for wood frame to hold body while off frame?
