Ignition on positive power in engine compartment
What's the best/easiest way to get a positive lead that's on with the ignition in the engine bay to use with my electric fan relay?
[Modified by Schmucker, 6:36 PM 3/18/2004]
Re: Ignition on positive power in engine compartment (Schmucker)
I believe that it is the yellow lead to the wiper motor switched
[Modified by shoptek, 7:48 PM 3/18/2004]
Okay, thanks, excellent.
Any suggestions on where I should put the thermostatic switch? The hole on the thermostat housing and the hole next to it on the intake are used. Where else can a hole that size be found?
I ran my igintion relay for the fans directly from the fuse box. I hate messing with existing wires and/or tapping them.
Usually a tapped hole in each head, your tem gauge should be hooked to the driver head so check you passenger head up near the fire wall.
