How strong is 69 rearend
just built a 406 with 294h cam,pro 1 heads 2:05 valves and 750 double pumper and alot other good stuff,plus want to hit with nitros so how strong is rear end hope to push 600 hp without hurting it
Re: How strong is 69 rearend (mikesfst69)
600 hp on a stock Eaton is pushing it. You can rebuild it to take the power but I wouldn't be dumping the clutch with a 30 year old stock unit.
To rebuild one for HD use you need to go with some new gears,treated 10-17 posi gears,solid clutches,steel bearing caps with 1/2 bolts,treated yokes,maybe even shoe horn a 12 bolt in there. Look for about $1,000 if you do it yourself or about $2,500 from Tom's.
Premium Supporting Vendor
Re: How strong is 69 rearend (Corey 68)
W/a fresh rebuild and new gears your rear should hold the 600HP. When you start jumping up another 150-200HP I would than seriously consider running the 30 spline kit. Here's a pic
Here a link http://www.vansteel.com/index.cfm?fu...&SubGroup=1878
Re: How strong is 69 rearend (gtr1999)
[QUOTE]I wouldn't be dumping the clutch with a 30 year old stock unit./QUOTE]
Your rear end will last as long as you don't dump the clutch, mine is one year older than yours, and lot more engine, rear end is just fine....
Re: How strong is 69 rearend (GDaina)
I have a 454 with about 650hp(all motor). The rear end was the only thing that has'nt broken yet. I took it to the drag strip and broke the driveshaft and the trans, but not the rear end. I have a Tom's 12 bolt on the way that i had bought from a forum member. I thought may as well get something stronger before we brake something back there.
D.Cruea79454
[Modified by D.Cruea79454, 8:19 PM 3/17/2004]
D.Cruea79454
How lucky do you feel??? Do you trailer your car to the track or do you have to rely on it to get you back home?
Do yourself a favor and buy the HD parts from "Van Steel" or "Tom's Differentials"...it will save you a lot of grief.
Deen
Deen
Re: How strong is 69 rearend (D.Cruea79454)
D.Cruea
Are you still running your stock driveshaft and pinion yoke? You can get a 1350 pinion yoke that will be stronger. The only downfall is that you need to get a 1" shorter driveshaft. But it will hold a lot more HP.
Re: How strong is 69 rearend (Van Steel)
Van Steel,
I had a 3" drive shaft custome made withe heavy duty yoks. The 12 bolt will have a 30 pinion yoke. Now that the trans has been rebuilt and a 12 bolt rear end i am not sure what will be next... Thanks
