Will ZO6 style wheels from camaro fit 1980 corvette. More info inside
My question is this, What offset is needed and will the ZO6 wheels for the camaro fit, they are 17 x 9.5 in front and 18x9.5 in the rear. If need be i could run the 17x9.5 on the back also. Does anybody out there have these on thier car. If so did you have to use spacers.
Thanks, John :seeya
Thanks, John :seeya
Re: Will ZO6 style wheels from camaro fit 1980 corvette. More info inside (ITSovr4U)
You'll need to achieve 4.0 to 4.25 inches of backspacing for the front and 4.0 to 4.5 inches of backspacing for the rear-depending on how you like the wheels to look/fit.
My guess is you have offsets for 4th gen F body, which means you will need adapters to make them fit the 1980 Vette.
Measure your Z06 rims backspacing and then make the simple calculation to determine what size adapters you will need. These adapters can be found everywhere at almost any size thickness nowdays.
Brent...
Brent...
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
