Oil Pressure relief valve spring
Where do I purchase a new oil pressure relief valve spring? This is for a stock pump. Is this strickly a GM part from GM or do most of the auto parts store carry them?
Re: Oil Pressure relief valve spring (tom102)
You might try Summit or GM Performance parts. When I bought my engine kit from summit they included an extra normal pressure spring for the high volume/high pressure pump. They may sell it separately. If not I believe GM sells it. Good luck.
