'79 Electrical Problems
2nd Gear
Flashers, high beams, turning sigs and wipers are inop. Headlights work but go black when I switch to high beams. Horn, radio, brake, back-up, dome etc all work. Thereis a noise from under the dash when I try the wipers.
Appreciate any help.
[Modified by mf79vette, 5:44 PM 3/15/2004]
Re: '79 Electrical Problems (mf79vette)
WoW, sounds like several problems actually. Each problem is more or less unrelated. You will need to describe each symptom a little better for proper diagnosis. Start by checking the HL bulbs, dimmer or switch. Check all bulbs in the signal system. Check the ground on the wiper motor.
Location: Boone NC home of 3peat National Champs ASU Mountaineers
St. Jude Contributor
Re: '79 Electrical Problems (toyvet1)
I'm blowing fuses to the instrument panel and tail lights. I feel your pain.
