Lost my panel lights....Help!
While replacing the center gauge cluster and radio, I shorted out one of the instrument panel light sockets. I replaced the fuse, but now I only have dash lights when I turn the **** to the far left (counter-clock-wise), position. This normally turns on the interior lights (which it still does). Any ideas out there?
Thank you.
Michael
Thank you.
Michael
Location: Sometimes I wonder... why is that frisbee getting bigger? Then it hits me.
Cruise-In X Veteran
St. Jude Donor '06
Re: Lost my panel lights....Help! (73 Vet)
Sounds like you may have blown out the dimmer switch. Get a new one
Re: Lost my panel lights....Help! (Madmikeee)
if it is only one or two lights, make sure the socket is plugged all the way in and making a good connection. Alot of the bulbs only have a positive wire and require the socket to be grounded to the metal assembly before they will work.
Re: Lost my panel lights....Help! (lostpatrolman)
Thanks, but they are all grounded and all work the same; only when the switch it turned to the "interior light" position. The dimmer switch was mentioned by madmikee. Can you tell me if you've had a simular problem?
Cruise-In X Veteran
St. Jude Donor '06
[Modified by Madmikeee, 2:06 PM 3/16/2004]
Snowbanking, sounds fun. After hearing stories like that, I feel like im missing something with the lack of snow here in florida
I can relate to snow-banking; been there, done that, got the shirt. Was it the headlight switch you replaced?
Thanks. P.S. have you tried "cow tipping"?
Cruise-In X Veteran
St. Jude Donor '06
And no... I....have...never...heard...of...cow.... tipping
:leaving:
I want to try cow tipping, but i would have to travel over an hour to get into the country. Not worth the time to push over a sleeping cow.
