Which is better
Cruise-In IV Veteran
Cruise-In V Veteran
Which is better
Accel/lingenfelter superram
or the
Holley stealth ram
I am looking for a 6500rpm potential with possible forced induction later.
I am personally leaning toward the stealth ram, but if anybody knows where I can get some empirical data comparison that would be great.
Thanks for your time.
Jake
or the
Holley stealth ram
Jake
Re: Which is better (Guru_4_hire)
Check out www.thirdgen.org in the tpi section, you might need to do a search but I believe there is info on it from Grumpyvette, believe he is also over in C4 so you might give him a shout there.
BTW the HSR is much cheaper and I know flows pretty good.
[Modified by Fevre, 2:27 PM 3/15/2004]
Cruise-In V Veteran
Re: Which is better (Fevre)
I think I will go with that one. It looks like it would flow good. I wonder how it would compare to carbeurated intakes.
