T-Top adjustment ?
Re: T-Top adjustment ? (Budman78)
Check your email.
...in a bit... I'm having trouble finding the scan. :confused:
[Modified by Pacin'California, 9:15 AM 3/15/2004]
Location: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Re: T-Top adjustment ? (Pacin'California)
If you don't mind, I'd like to get a copy of that also.
jgcox77@hotmail.com
Thanks
jgcox77@hotmail.com
Thanks
Re: T-Top adjustment ? (stingraymaniac)
Boy I sure could use one as well!!
Thanx in advance
hstein@devolvecorp.com
[Modified by VettePower, 7:16 PM 3/15/2004]
Thanx in advance
Location: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In IV Veteran
Cruise-In VI Veteran
Re: T-Top adjustment ? (JBR)
Can you post it on here? :cheers:
If not can you please send a copy to: snodrgn@earthlink.net
:cheers:
St. Jude Contributor
http://images.cardomain.com/member_i...9/531991_6.jpg
opps...too small.
[Modified by brooksman9, 4:36 PM 3/15/2004]
http://www.cardomain.com/memberpage/531991/3 try this
[Modified by brooksman9, 4:40 PM 3/15/2004]
[Modified by brooksman9, 4:42 PM 3/15/2004]
opps...too small.
Cruise-In VII Veteran
St. Jude Donor '07
Re: T-Top adjustment ? (brooksman9)
One of my passenger t's it high in the middle corner. It does not have any shims under the post. The weatherstripping is new, so I'm I just screwed or can I adjust the female plug also.
Oh I forgot Thanks Paci
You can adjust the bayonet receptacle down if need be but not very much, at least not with the existing screws as they just are not very long. I dropped mine on my passenger side of my '80 by a couple of washer widths or so using the factory screws. I too, am battling all sorts of weirdness after replacing my disintergrated T-top weatherstripping so I know how you feel.
78-82 :leaving:
Re: T-Top adjustment ? (CVT4ME)
Re: T-Top adjustment ? (John65,80)
I feel your pain. My passenger side came out fairly well but the driver side is giving me hell. It seems like the window won't quite reach the weatherstripping in the corner where the latch is. What is very odd about all this is that the T-tops are now sitting lower than they ever have before and the window is adjusted to go up as high it possibly can. It was all good before I started down this road of weatherstip replacement, though the stripping was in bad need of replacement.
CVT4ME
CVT4ME
