Fuel pump, mechanical or electric?
Re: Fuel pump, mechanical or electric? (BlackRat)
unless you're building a Pro Stock, 3/8" lines are fine. Electric pumps are noisy as heck, nothing wrong with a mechanical pump...the mechanical pump will collapse the tank if the wrong gas cap is used....aks me how I know... :sad:......therefore, the mechanical pump can deliver the fuel to more than meet the engine's needs.
Great thanks for the info. :thumbs: Are the stock lines 3/8's? They look smaller than that. :confused:
Wade
Wade
Stock fuel lines is 3/8"..I was thinking of changing them my self to a bigger size,but if they can flow enough for the LS6/7 and L88s,then they are enough for me to.. :smash: :cheers: :cheers:
I am a fan of electric pumps mount under the tank. In both my cars I run 2 high pressure holley bumps, each feeding directly off it's own fitting at the bottom of the tank. I also run a 1/2 stainless fuel line up to the regulator when the 15 or 16 psi pressure is reduced to 6 psi.
I also have found rubber mounts sold by a local screw supplier that takes most of the noise away, not all but most. They bolt to the holley pumps and have a 1 inch vulcanized rubber flange.
Re: Fuel pump, mechanical or electric? (norvalwilhelm)
Re: Fuel pump, mechanical or electric? (GDaina)
I will post pictures tonight. I have them on my home computer.
It is 2 flanges seperated by 1 inch of rubber, like motor mounts designed to cut vibration in equipment.
See what you think of them.
Come, come, someone has to ask this. GDaina, how do you know that the mechanical pump will suck the tank in? (I just want to hear someone else aknowledge the kind of mistakes I make). :smash:
Steve
Steve
Re: Fuel pump, mechanical or electric? (Steve's74)
Daaaaaaaaah....by putting on a non vented cap on a vented system...yup, that's what I did...i put a locking non vented cap on my 68...you should have heard that gawd awful noise when teh tank collapsed....
Norval has dual lines each feeding a carb . . . Who woulda thunk it? :lol: :lol:
