Exhaust casting numbers needed.
CF Superior Member
St. Jude Donor '07, '11-'12-'13-'14-'15-'16-'17-'18-'19-'20,'21-'22-'23-'24
Official Sponsor of the 60 Day VacatioNN
10,000 poster in the "thread" Part II
How can I determine what the correct part number is for a 69 427 engine exhaust manifolds. I dont think the ones on there now are stock and one is cracked and in need of replacement. A friend of mine is restoring his and would like to know. the VIN number is 194379s720769 if that helps. supposed to be an L36 390 hp. Thanks... any info would be appreciated. :thumbs:
Re: Exhaust casting numbers needed. (Daniel90conv)
left hand is 3880827 and right side is 3880828, there is a casting number on back side only visible when removed or from underneath maybe with flashlite to identify correct month/year for car, if not interested in date matching then any with above first two numbers will work from 66-74 :cheers:
CF Superior Member
Re: Exhaust casting numbers needed. (LT1driver)
Wow That was fast!! I knew Icould count on the forum. Thanks much!! :thumbs: :thumbs:
