Vented or Non-Vented?
1981 Gas Cap is it vented or non-vented. :confused: I had the Vette parked outside so I could do some work on it and late tonight this a very stronge smell of gasoline. :eek: Went to check it out and found fuel leaking carb gasket or seal. :mad I think I have the un-vented locking gas cap... I unlocked it and relieved the pressure from the gas tank. :yesnod:
Re: Vented or Non-Vented? (Intimidator454)
If by unlocking it you relieved the pressure then I would think it's non vented. The original should be non vented also. Craig
