Who sells shorter rear springs?
Looking to lower my car and need a shorter rear spring. Who carries them? Are the shorter ones only available in steel or are there composite ones too?
Re: Who sells shorter rear springs? (70 LS1)
Um, you can just get longer spring bolts if lowering is what you're concerned about.
If you need a narrower spring, VBP and Van Steel can accomodate you.
-Steve
-Steve
dual mount manufactured by VBP dropped the back of my car.
Re: Who sells shorter rear springs? (Pacin'California)
Shorter rear springs?
:lolg: :lolg:
I know what you meant but it's still funny. Use VB bolts for $25 and you'll be lowered like my car in pic. below
[Modified by Cali,68,L-79, 7:00 PM 3/12/2004]
:lolg: :lolg:
Re: Who sells shorter rear springs? (Cali,68,L-79)
Maybe I should explain so I don't come across as ignorant.
I have 18x9.5" rims on the back of my car and the ends of the spring sit inside the wheel. If I go with longer 8" bolts, then the tire will rub the spring. I am looking for a narrowed or shorter leaf to bring the mounting points of the bolts in away from the tires.
Thanks, Cali
I know that Guldstrand has one, but there stuff is so overpriced. I will check with Van Steel.
Yeah, VBP and Van Steel both should offer narrower rear springs...
-Steve
-Steve
