Harmonic Balancer
Harmonic Balancer
Does the corvette need a different harmonic balancer than the typical SB type? I would assume the only reason for something different may be due to the width so the pulley line up. Any help would be appreciated.
Mike
Mike
Received 4,919 Likes
Re: Harmonic Balancer (mandm1200)
Vette uses the same one as any other SB, but there are different diameters and configurations by year. Pulley mounting face location remains the same.
[Modified by lars, 9:40 PM 3/11/2004]
Re: Harmonic Balancer (lars)
what about going to the cut 400 crank "383" got new flywheel coming ,found
the GM roller cam is going to be work, :banghead: :banghead:
Re: Harmonic Balancer (comp)
:confused: huh?
400 balancers are different than other small blocks in configuration, but the depth from face to block is still the same.
