80 exhaust vibrating against bottom of differental. Am I missing a hanger?
The rear Y pipe is making lots of noise at the heat shield under the differental. Is there suppose to be a hanger there? There's one just forward of it but its vibrating by the heat shield. Thanks
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: 80 exhaust vibrating against bottom of differental. Am I missing a hanger? (John65,80)
If I remember right, there is one right behind the converter and then nothing until the mufflers.
The heat shields were tack welded on. Maybe one of the welds has broken.
Re: 80 exhaust vibrating against bottom of differental. Am I missing a hanger? (BSeery)
Thanks, I'll have to check tommorow.
