vacuum system question
Would installing a check valve backwards make my headlights inoperable?
I am thinking it would.
[Modified by Kevin Mason, 10:00 AM 3/11/2004]
Re: vacuum system question (Kevin Mason)
The check valve is one way directional, you are correct.
The only check valve on my 72 is right after the manifold vacuum fitting that feeds all the systems. Blow into the check valve...that should tell you flow direction.
Eddie
Eddie
