Tire Size on a 72?
Tire Size on a 72?
Thinking about some 245x60 fronts and 255x60 rear tires on my stock 72
with 15x8 rims. Anyone else have this tire set up- if so- any problems with tire
rub or other issues with using this size?
Thanks CDC
Thanks CDC
Re: Tire Size on a 72? (cdc)
I have 245 60 16s all the way around with no rubbing at all. I tried my neighbors 255 60 15s and they rubbed a little in the front. The rears were fine. These were on a set of 81 alloy rims and I don't know if the offset is any different. You should have no problem running what you want.
Thanks CDC
Thanks CDC
The smaller 245x60's will work better on the fronts than my setup IMO. :chevy
Re: Tire Size on a 72? (Gordonm)
I have 245 60 16s all the way around with no rubbing at all. I tried my neighbors 255 60 15s and they rubbed a little in the front....
Don't have that prob. here ! :jester
:flag I have a 1972 Convertible. I recently installed P235/60/15 on the front and P255/60/15 on the rear. No problem. I had to turn the parking break clip to one side on the rear but that is not a problem either. I ran 235/60/15 all around previously. :thumbs: :cheers:
