CAST NUMBERS FOR STOCK EXHAUST MANIFOLDS FOR 68
I have a local friend that has most if all the parts I need but I need the casting numbers for the exhaust manifolds.
Dave i will have to check my shed ( i have duty tomorrow) i can give you availability and prices on wed if thats ok.. check my notes in caps >
> 1. Stock iron intake with oil fill # 3919803 ( I SHOULD HAVE THIS ONE.
> 2. Q-Jet #7028219 ( I HAVE 50 TO LOOK THRU..) AGAIN I SHOULD HAVE IT.
> 3. Single belt top pulley (NO PROBLEM)
> 4. Fan clutch (2 CORRECT ONES)
> 5. Stock 5 blade fan (YES I HAVE 2)
> 6. Gas line from mech pump outlet to carb inlet (DEFINATELY)
> 7. Exhaust manifolds, period correct( I WILL LOOK THRU THE PILE,,DO YOU ALREADY HAVE THE NUMBERS OR DO I NEEED TO LOOK THEM UP) LET ME KNOW IF YOU NEED ANYTHING ELSE
Thanks for stopping by, VettSteve
Re: CAST NUMBERS FOR STOCK EXHAUST MANIFOLDS FOR 68 (Cali,68,L-79)
David, did you add in $1200 for the "smog" system :lolg: I have all the parts you need X 2 but really can't sell any, sorry :lolg:
I'm not sure on the casting numbers, but I do know '68s smallblocks had a unique left exhaust manifold where it had a "tapped" hole at the very front for the lower mounting of the alternator bracket-not sure if this was used in '67 or if '69/'70 had this set-up. I know my '74 & '75 don't. I believe the heads on a '68 don't have the extra accessory holes that later years had.
[Modified by Paul Borowski, 9:24 PM 3/9/2004]
Re: CAST NUMBERS FOR STOCK EXHAUST MANIFOLDS FOR 68 (MNJack)
left 3872765
right 3872778
:) MJ
right 3872778
:) MJ
For the Big Block guys the #'s are 3880827 (LH) and 3880828 (RH) ;)
