Demon Throttle Cable Question
I installed a Mighty Demon on my 71 small block. The stock throttle cable and bracket (for the original Holley 780 cfm) do not line up properly. Any ideas on a throttle bracket set-up that will enable me to use the stock throttle cable. Thanks
Re: Demon Throttle Cable Question (SC71LT1)
Well, I first used a bracket from Russel which turned out to be a flimsy POS.
My new bracket is from CSI and it is listed for 3310 Holley, but works with the demon. I have yet to hook it up, but can let you know in the next few days.
:cheers:
:cheers:
