C3 Tires
1st Gear
C3 Tires
I have a 70 Ttop 350/350 which is mostly stock with the exception of composite rear spring. Has the original wheels. Would like to buy some new tires, wider than the current 225-70s. Would Goodrich 255-60 tires fit my vette without modification? Any other recommended tires? Thanks
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Re: C3 Tires (HighOctaneRequired)
Yes, I believe I'm running the 255 60's with no issue. I went to Goodyear and bought a set of Eagle GT II's. The initial quote was over $500. But after threatening, twice, to walk out, the price was a little under $350 out the door. That's mounted, balanced, valve stems, etc. So it pays to dicker.
And the wider tire looks a heck of a lot better than the original.
:cheers:
:cheers:
St. Jude Donor '04 & '05
Welcome to the insanity! :crazy:
255 - 60's should work fine on your car. That's what I'm using with no issues. FWIW.
Good Luck!
:seeya
Good Luck!
:seeya
