Rear shock absorber length?
I've heard recently that rear shocks should have a maximum extended length of 14.25 inches. I measured mine and it was 15.5 inches. Supposedly, this can cause binding between the half shaft and the stub axle. Has anybody else heard this?
Re: Rear shock absorber length? (BKbroiler)
Yes, Bair's Corvette warns about this when they do a trailing arm rebuild. They sent me a sheet about this very thing when they returned my T-arms. It's true.
I also had my differential rebuilt by Bairs and there was a warning about the overall extended shock length. I called them to ask what brand of shocks I should use. They could not recommend anyone. Does anyone no what shock manufacturer meets this requirement? :steering:
Interesting, I just measured my KYBs at 14.75". From what you guys said that's not good.
Re: Rear shock absorber length? (burners)
Hmm, that's not good, I have KYBs too. Full droop doesn't happen too often in the rear, but I guess it could. Is there some way to install "straps" to stop travel??
-Chris
-Chris
