rear deck spacing along with stereo set-ups
Re: rear deck spacing along with stereo set-ups (1FUNVET)
Come on guys I need some visual help here. I want to what people have done considering the rear deck spacing we have and the fact that it's supposed to hold the t-tops. I want to see everyone has the speakers and such in the back.
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Here is what I've done. Pardon the non-finished look, the trim pieces are still off in the pics.
Good luck and have fun... :cheers:
Re: rear deck spacing along with stereo set-ups (Rogue Wave)
I was thinking about mounting some shallow speakers on the doors of the rear compartments. Maybe move the battery to the center compartment if i needed the extra room. Would this produce decent sound? I havent seen it done before.
Re: rear deck spacing along with stereo set-ups (lostpatrolman)
The center compartment? Have you looked at it recently?? It's about big enough for a pair of gloves and some extra bulbs (what I have in there). I believe the driveshaft is directly under it.
There are some specs, somewhere around here, for mounting rear speakers. What you end up with is something identical to what Rouge Wave has done.
I used these specs to mount 6X9s in the rear of my '76. Also mounted the essential fire extinguisher between the speaker enclosures.
When there is a stereo in, I run a tweaked home speaker set. One large amp. in the center compartment for the removable rear speakers w/ 2 long throw 4s (equil. to 2 8s) & a dome in each.
It ROCKS !
Rarely use it. The engine makes enough music for me.
:cool:
It ROCKS !
:cool:
Hey these are some great idea you all have. Keep them coming I wanna see what else everyone has, so my hubby can then "copy" one of your great outcomes!!! :seeya
I think this setup is pretty cool!!
I found the pictures at http://www.corvettesdownunder.com.au
[Modified by Tomi72, 4:31 PM 3/9/2004]
Re: rear deck spacing along with stereo set-ups (Tomi72)
[Modified by Tomi72, 12:39 PM 3/9/2004]
Location: Sometimes I wonder... why is that frisbee getting bigger? Then it hits me.
Cruise-In X Veteran
St. Jude Donor '06
I am going to be modifying my old sub box with 2 10" subs to fit back there I will then add mids and tweats to the front of the car with a small amp and I should have a pretty kick azz system with plenty of room for the tops in their bag,, But that will be later down the road.. I have alot of stuff to do before that happens :)
Cruise-In X Veteran
St. Jude Donor '06
Re: rear deck spacing along with stereo set-ups (79VetteMike)
[Modified by Tomi72, 12:39 PM 3/9/2004] :iagree: :iagree: That is one of the slickest mods I've seen on a C3!!!!
Too bad that setup would be wasted on my 77 as it is a "notchback", can't show it off :) But that gives me some ideas.. Did that guy give out plans by any chance?? :lol:
Re: rear deck spacing along with stereo set-ups (Madmikeee)
Re: rear deck spacing along with stereo set-ups (battsup)
I want to THANK everyone who took part in this. Me and my hubby will be yanking out the stereo in my car when we are re-doing the interior, you guys have some great ideas. I will post mine once it get done.
:cheers:
:cheers:
