Failed Inspection-HELP
82 Collector's Edition---47000 mile
NOX 111 pass
HC 321 fail
CO% 4.83 fail
C02 9.5 pass
O2% 3.7 Pass
Any help would be appreciated.
Thank you
NOX 111 pass
HC 321 fail
CO% 4.83 fail
C02 9.5 pass
O2% 3.7 Pass
Thank you
Re: Failed Inspection-HELP (delpa)
How does it run and idle???
It's running rich, check the coolant temp sender in the front of the manifold first, also check it's connection. If it's the old style connector with the round connector replace it with a C4 model with weatherpack connector. Set TPS to 0,525 +/1 0.25V at idle (key on engine off). Also check for exhaust leaks (false lean O2 signal) and check the air check valves on the headers and the switching valves. If the air system does not switch to the cat con in closed loop you will get a false lean signal and it will be running rich.
If I recall correctly, low NOX with high HC and CO indicates a poorly functioning or non-functional catalytic converter. You might also check your air pump and your air-fuel mixture (O2 sensor). But I don't know much about cross-fires.
Jeff
Jeff
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: Failed Inspection-HELP (no_radio)
I would make sure the O2 gage is working correctly, then look at the cat. and also check to see if the AIR pump is putting out any air.
Jeff
Jeff
Thanks for all your recommendations. I will check
Could a bad spark plug cause this?
[Modified by delpa, 9:37 AM 3/7/2004]
