Mixing ratio for PPG DP48 and DP402???????
Old 03-06-2004, 09:16 AM
Dalannex
Dalannex's Avatar
Default Mixing ratio for PPG DP48 and DP402???????
Primer sealer PPG DP48 and catalyst DP402- It's been awhile since I painted my car and I seem to have lost the mixing ratio instructions that I got from my paint supply shop. What is the mixing ratio for this primer sealer and catalyst. I do remember I had to reduce it a little bit.
-Justin
Old 03-06-2004, 10:21 AM
tom102
tom102's Avatar
Default Re: Mixing ratio for PPG DP48 and DP402??????? (Dalannex)
Justin,
Here is the email address for Paul at PPG paints he canb answer all your questions
paul@ppgpaint.com
Old 03-06-2004, 10:48 AM
Dalannex
Dalannex's Avatar
Default Re: Mixing ratio for PPG DP48 and DP402??????? (tom102)
Thanks, email sent. But, if anybody else here has that info handy feel free to jump right in anyway.
-Justin
Old 03-06-2004, 11:06 AM
White 68
White 68's Avatar
Try this link they have mixing ratios and other tips on the p sheets
http://www.pwpaints.com/ppg-p-sheets.html
[Modified by White 68, 11:54 AM 3/6/2004]
Old 03-06-2004, 02:32 PM
stpman
stpman's Avatar
Default Re: Mixing ratio for PPG DP48 and DP402??????? (White 68)
Here's the data sheet for DPLF402 (replaces DP 402)
http://www.ppg.com/cr-refinish/phase...indProduct.asp
mixing ratio is 2 parts epoxy - 1 part DPLF402 - 1/2 reducer.
Steve :steering:
Old 03-06-2004, 08:28 PM
lars
Support Corvetteforum!
lars's Avatar
Received 4,916 Likes on 1,928 Posts
Justin -
If you have the old DP48 and DP402 the mixing ratio is 1:1. You can also reduce this slightly (up to 10%) with DT870.
If you have DP48LF and DP402LF (LF=Lead Free), the mix ratio is 2:1. Don't combine any of the LF products with the old products (don't use 402LF with DP48 - use LF products only with other LF products)
Old 03-06-2004, 11:19 PM
Dalannex
Dalannex's Avatar
Default Re: Mixing ratio for PPG DP48 and DP402??????? (lars)
Thanks Lars. That's just what I needed to know. :seeya
-Justin
To Mixing ratio for PPG DP48 and DP402???????
Quick Reply: Mixing ratio for PPG DP48 and DP402???????
