Trading reverse lights for brake lights, how to ??
Old 03-05-2004, 09:10 PM
motown 71
motown 71's Avatar
Default Trading reverse lights for brake lights, how to ??
I am going to do this but wondered if I can use the same receptical, or will I need to remove the current reverse light receptical and install another.
I am hoping to simply jump some wireing and be done, ???
Thanks ! :flag
Old 03-06-2004, 12:32 AM
SCCACFC
SCCACFC's Avatar
Default Re: Trading reverse lights for brake lights, how to ?? (motown 71)
:confused:
Old 03-06-2004, 07:04 AM
Paul L
Paul L's Avatar
The reverse socket is single filament so you need a double filament socket. Do not remove the old, you may wish to revert back to it for inspection/safety check purposes. Simply scotch-lock the new socket wiring into the existing tail/brake wiring.
Example. The black wire is the old that you do not wish to cut. It is linked to one wire (red) of the new socket by the lock. That lock is easily removed.
The end result is four tail and four brake lights. The uncut reverse sockets and wiring can be neatly tucked away with a nylon tie. Some regions require back-up lights for a safety inspection and the intact wiring will be ready and waiting if that need arises.
[Modified by paul67, 7:15 AM 3/6/2004]
[Modified by paul67, 7:22 AM 3/6/2004]
Old 03-07-2004, 07:33 PM
motown 71
motown 71's Avatar
Default Re: Trading reverse lights for brake lights, how to ?? (paul67)
That's exactly what I'm after !
Thanks Paul
:cheers:
To Trading reverse lights for brake lights, how to ??
Quick Reply: Trading reverse lights for brake lights, how to ??
