First time Front End Rebuilt........UPDATE and Torque Question
Vetters,
Began the front end rebuild Sunday. My expert never showed to help. I have never under took a project like this before. What a man will do to save $750 in labor . I took LARS TECH paper and began myself. That TECH paper is the cats butt. I looked at it , then the shop manual. No comparision. Short sweet and to the point. Took me about 6 hours to get everything off except the upper control arms. Did those today, about 1 1/2 hours. Passenger side was a pain in the butt. Hardest part so far was getting the upper ball joints off the control arm. Used an air chisle, grinder, punch BF Hammer. Air chisle did not work form me at all. The grinder was the best way to get the rivets off. Figure I will get the bushings out this week, then sand blast the arms then paint them. Not looking forward to getting the bushing out. Any sugestion on putting the TIE ROD ENDS on, as far as measuring the old ones?
MID WEEK UPDATE:
Removed UPPER control arm bushings..........Holy smoke...3 came off as discribed buy LARS Tech paper. The 4th was a royal PITA. 2 hours to get the 4 off. Sanded and painted uppers. Need to install the bushings and ball joints to uppers tomorrow. Lowers stil need to have the bushings removed. I needed a day to recouparate...2 hours on a AIR CHISLE is way to long. Went to bed and my ears were still ringing, not to mention my right arm was like a wet noodle..
Friday; Daughter and I went to the Auot Hobby Shop and sandblasted Lowers and spindle assembly.
Sunday; EVERYTHING is all painted, bushing installed, ball joints installed, cleaned under the car. LOOKING GOOD......... Was getting ready to install........but decided I would replace the steering box while I am at it. Got one from a Forum member last year. It's amazing what kind of little things can be done while it jacked up to moon. I was thinking about replacing the oil pan gasket......think I will wait.
Randy
[Modified by Randy 71, 6:48 PM 3/4/2004]
[Modified by Randy 71, 6:57 PM 3/7/2004]
MID WEEK UPDATE:
Randy
Re: First time Front End Rebuilt........UPDATE and Torque Question (Randy 71)
You said you have the shop manual, isn't it in there? (beginning of the section). I believe all the balljoint to control arm torques are 25 ft. lbs. Don't remember the rest. The funny looking fat-headed bolt is a secondary steering stop and goes to the front of the car. Measure your upper pivot shafts, norval's are offset, whereas mine and TwinTurbo's aren't!! Don't want to get them reversed and end up with tons of shims.
Picture this, I had to do this in 5 days before I drove from North Carolina to Kansas! And I did the bushings the hard way and spent 2 days on them alone.
Good luck :cheers:
-Chris
Good luck :cheers:
-Chris
Randy,
Where did you find Lars paper????
I'm gettin ready to do the front end on my '71 also!!
Re: First time Front End Rebuilt........UPDATE and Torque Question (shoptek)
shoptek,
I have it on my home computer. I will get it for you this afternoon.
Sounds like your making some good progress. I wish I would have had the guts and time to have done mine myself. Are you changing the front springs too?
shoptek,
Thanks!!! I'm looking forward to it!
Re: First time Front End Rebuilt........UPDATE and Torque Question (74 vert)
74 vert,
Yep...springs, shocks etc............ figured after 33 years it was time.
shoptek,
Complete Corvette Front End Rebuild
Tools needed:
1. Floor jack
2. Jack Stands
3. Air Compressor
4. ½ Impact Drive
5. Air Hammer/Chisel) with radiused chisel, straight chisel and pickle fork attachments
6. Pickle Fork
7. Spring Compressor (not required for small block)
8. Big Hammer
9. Complete socket sets in 3/8 and ½ drive
10. ½ and 3/8 drive ratchets with extensions
11. A Cheap Taiwanese ¾ drive socket set
12. Combination wrench set from 5/16 thru 15/16
13. Screwdrivers
14. Pliers
15. Pin punch set
16. Torque Wrench
17. Heavy Duty Vice mounted to a solid workbench
18. 3/8-drive air ratchet with a set of deep sockets
19. Masking Tape
20. Felt Marker
21. Box Knife
22. 220-grit sandpaper or emery cloth
23. Assembly Lube
1. Raise the front of the car off the floor and secure it with jack stands under the frame, allowing the front suspension to be un-supported. Make sure your floor jack has enough height travel to reach the bottom surface of the lower a-arms with the car in this raised position. Also, make sure the car is high enough to allow the lower a-arms to swing all the way down to the near-vertical position. Remove the front wheels.
2. Disconnect the flexible brake lines from the wheel cylinders or at the frame brackets. Cap the line with a bolt or plastic cap to prevent brake fluid from dripping from the line.
3. Remove the front shocks.
4. Remove the front stabilizer bar and the entire bar attachment hardware.
5. Remove the cotter pins on the nuts securing the upper ball joints, lower ball joints, and outer tie rod ends. These are often rusted in place, and can be a challenge to remove. Use the Band-Aids as required.
6. Loosen the ball joint nuts and the tie rod end nuts so that the nuts are backed off to produce about 1/8 clearance from the bottom surface of the nut to the seating surface, but do not remove the nuts completely.
7. Using the air hammer with a pickle fork insert, pop the tie rod ends loose. Once they pop loose and slam against the loosened nuts (the loose nuts will retain the parts so they don’t go flying through the air when they pop loose), remove the nuts, remove the tie rod ends from the spindle, and tie the tie rod end assembly up out of the way with some string or wire.
8. Insert the air hammer pickle fork into the upper ball joints and pound away until spring pressure pops the ball joint away from the spindle and up against the loosened nut. Do this on both sides.
9. If you’re working on a small block car with stock springs, you do not need to use a spring compressor. You can do this in the sequence we did as follows. Big block cars can also be disassembled in this fashion if care is taken when popping out the springs, but a spring compressor is safer on the BB:
10. Bring your floor jack up underneath the spring pocket of the lower a-arm and raise the jack and the arm until you see the upper ball joint nut slacken off the spindle. Remove the upper ball joint nut. Slowly, lower the floor jack. The lower arm with the spindle/brakes will drop down and disengage from the upper ball joint, and the spring will go completely slack. Once the arm has dropped all the way down, simply remove the loose spring there will be no tension on it, and it will pretty much fall out on its own. On big block cars, you may need to install your spring compressor and squeeze the spring before dropping the arm as described.
11. Once the spring is removed, bring the lower arm and spindle back up and engage the upper ball joint stud to the spindle. Loosely attach the upper ball joint nut to join the assembly. Let it all hang like this, and take the air chisel to the lower ball joint, which is now not loaded by the spring. The air chisel will usually knock the lower ball joint stud out of the spindle once the spring has been removed. If it doesn’t, use your pickle fork and big freaking hammer (BFH) until the joint pops loose. Once loose, remove the upper and lower ball joint nuts, and remove the entire spindle/brake assembly from the car. Repeat the whole process for the other side.
12. Remove the bolts (3) holding the lower a-arm to the frame. A ½ drive impact gun is good for this job. Remove the lower a-arms.
13. From the topside of the engine compartment, loosen the 2 nuts holding each of the upper a-arms to the frame. As you loosen these nuts, pull the entire alignment shim pack off each location, tape each pack together, and label them as left front, left rear, right front, and right rear. Once the shims have been removed, taped, and labeled, remove the nuts.
14. The driver’s side upper a-arm can easily be removed by wiggling it off the studs and pulling it out. The passenger side does not have adequate space to slip it off the studs, so the pressed studs must be removed. This can be done in several ways: Many of these studs are pressed loosely enough that you can wiggle the a-arm back and forth to make the studs wiggle. By having a helper pry against the studs while they’re wiggled, they will pop out. You can also use a C-Clamp against the protruding threaded end of the stud while placing a large socket over the head of the stud. You have to have just the right sized C-clamp to do this. You can then press the stud out into the socket covering the head. Finally, if the studs do not want to come out, you can put a socket onto the stud head and give it a few zaps back and forth with your ½ drive impact. This will loosen the knurled shank of the stud in the frame, and the stud can be wiggled out. If you do this, be careful about how much you hit the stud with the impact gun you just have to BARELY give it a few whacks in each direction to get it loose. If you really pound in it you will completely turn the stud in the frame hole, and you will round off and destroy all the knurling. You will then need to buy new studs (available from any auto parts store). With the studs removed, the a-arm will come out from the wheel-well side of the car once you figure out just how to twist it to get it out of the wheel well opening (it really does come out).
15. Mark the upper a-arms with something to show which one is left and which one is right the arms are similar, but different, and it can be confusing which is which once they’re mixed up. The lower arms are obvious, since they have the stabilizer bar attach point on the leading edge.
16. This completes disassembly of the front suspension. If you are replacing tie rod ends and idler arm, this is the time to finish unbolting these components and using the air hammer as earlier described.
17. If your car has original ball joints, the upper joints are attached with rivets. These rivets are pretty soft, so simply clamp the a-arm in your vice and use a flat chisel insert in your air hammer to cut the heads off the rivets. Once the heads are cut off, you can use a pin punch and a hammer to knock the rivets out of the arms.
18. If your car has aftermarket ball joints, they will all be attached with nuts and bolts. Remove all the hardware and remove all the ball joints.
19. Now for the a-arm bushings. No press is necessary just your handy air hammer and a ¾ drive socket set. Remove the shaft bolts and washers from the a-arm assemblies. The uppers are smaller than the lowers, so you can’t mix them up.
20. Clamp one of the arms firmly in your vice so you have access to one of the bushings. Notice that on the inside of the bushing (the end away from where the bolt and big washer retains the bushing to the shaft) the rubber will be bulging and squeezing out. Using a box knife cut the rubber away from the bushing in this area. This will expose a small portion of the inner bushing sleeve where it slides over the shaft. The toughest part of getting the bushings off is due to these inner sleeves being seized and rusted to the shaft. Using your air chisel, place the chisel tip onto the inner bushing sleeve at an angle at this location and give it a few zaps. Hitting directly on this inner sleeve in this way will make the inner sleeve start to move off the shaft. Once it starts moving, use your radiused chisel tip at the other end of the bushing, forcing the chisel in between the outer large lip of the bushing and the a-arm. By walking the chisel around this outer lip and beating it away from the a-arm, the bushing will walk right out of the a-arm and off the shaft. You may have to alternate beatings between the inner bushing on the inside, and the outer lip on the outside.
21. Repeat this with all the bushings. Once you get this technique down, you can easily pop all 8 of the bushings out of the arms within 15 minutes.
22. With the bushings out of the arms, use a little sandpaper or emery cloth to smooth out, de-rust, and de-burr the bushing bores. Use a file if needed to remove any bigger burrs. Clean up the arms and paint them.
23. Sand and de-burr the a-arm shafts as well. Remove any rust and nicks on the shaft ends where the bushing will be installed. Clean them up and paint them.
24. You can now install your new ball joints. If the lube fittings are 90-degree fittings, install these so that the fittings point backwards. This will prevent road dirt from getting into them. Torque the ball joint attach hardware to the spec provided by the manufacturer.
25. The upper a-arm shafts should be able to slip all the way through the bare upper a-arm bushing holes. Verify this before proceeding. Coat the upper a-arm bushing holes with assembly lube. Lube the a-arm shafts where the bushing sleeves will be installed. If you have polyurethane bushings, remove the bushing inner sleeves and lubricate them with the lube provided by the manufacturer. Using a ¾ drive socket that is bigger than the bushing, clamp the socket in your vice, and place the a-arm over the socket. Insert the new bushing into the arm, and simply tap it into the arm by using a ¾ drive socket of the right size on the large diameter bushing flange. The bushing will tap right into the arm without distorting the arm as long as you keep it going straight.
26. Insert the a-arm shaft through the remaining empty hole and engage the shaft into the new bushing. Install the second bushing into the opposite end of the a-arm so it engages the shaft. Place the a-arm in your vice so that the vice provides backing for the arm, and tap the second bushing into position using a socket on the outer lip of the bushing.
27. This same process is used for all of the bushings the bushings can be hammered into place using a ¾ drive socket and a 5-pound hammer. Note that on the lower a-arms you need to install the shaft along with the first bushing since the shaft will not go into the arm once one of the bushings has been installed.
28. Install the shaft end bolts and washers loosely do not tighten.
29. Install the upper a-arms into the car. If you removed the arm attach studs, install the studs and seat them by tapping them into the frame with a hammer and a rod. Install the shim packs back into their original locations, install the nuts, and tighten it all up.
30. Install the lower a-arms using the hardware removed earlier.
31. Notice that the lower a-arms have a hole drilled in the lower spring pocket. This hole serves as a water drain hole. It also serves as an alignment hole for the spring. You want to install the springs so that the end coil of the spring comes right up against this hole, but does not cover the hole. With this in mind, install the spring and make sure it is correctly situated in the upper spring pocket. Use a flashlight so look at the pocket configuration, and make sure the spring is going in right. Stuff the spring up there, and use your floor jack to raise the lower a-arm up underneath the spring. If youÂ’re working on a big block, you will need to have a spring compressor on the spring. Small block cars can be assembled by hand. Simply raise the lower arm under the spring and use the weight of the car to compress the spring. Verify spring rotation to the drain hole. With the floor jack supporting the arm and compressing the spring, slip the spindle/brake assembly onto the lower ball joint stud and install the nut. Swing the spindle into position and engage the upper ball joint to the spindle. Install the nut. Lower the floor jack and remove it. Tighten and torque the ball joint nuts and install the cotter keys. Swing the tie rod end into position and engage it with the spindle. Torque and install the cotter key. Attach the brake hose.
32. Repeat this for the other side.
33. Slip the shocks back in and bolt them up. Install the stabilizer bar. Bleed the brakes. Lube the new ball joints, and drop the car down on the ground. With the full weight of the car on the suspension, tighten the loose a-arm bolts and get the car over to the alignment shop.
Randy 71
[Modified by Randy 71, 11:48 PM 3/5/2004]
shoptek,
Tools needed:
1. Floor jack
2. Jack Stands
3. Air Compressor
4. ½ Impact Drive
6. Pickle Fork
8. Big Hammer
13. Screwdrivers
14. Pliers
15. Pin punch set
16. Torque Wrench
19. Masking Tape
20. Felt Marker
21. Box Knife
23. Assembly Lube
Randy 71
Randy... thanks for the great detail. It brought back some haunting memories of the last 2 months. I have been working on this same project and should be finishing it up Sunday. :smash:
It would have been great to have this before I started, but it should really help anyone else who will be doing it. You made some of it sound very easy, but most of it I found to be a major PITA! But in the end, well worth it.
I do have one question, I was pretty stupid when I took it all apart, and didn't measure the threads on the tie rod ends. I will have it aligned when I am done, but any suggestions on the approximate measurement? THANKS!
Re: First time Front End Rebuilt........UPDATE and Torque Question (USA SHARK)
USA SHARK,
Driverside; I counted 8 threads showing on one side and 9 on the other.
Passenger; 13 both sides.
Hope this helps.
Randy
Hope this helps.
Randy
Thanks Randy. I thought it would probably vary, which means I'll probably just set them all about the same and let a pro align it quickly.
That will be a great help this spring. Previous owner did the upper bushings but not the lowers, seems kinda dumb since it sounds like the lowers are the first to be removed in the process.
