Richmond 5 speed users please step inside.
Really want a 5 speed that does not require major surgery to my vette and the richmond 5 speed looks to be a nice fit but would like some more feed back on it. I now there is info in the archives but would like some up to date info from new users and people who have been using ti for a while.
Does the Long shifter that comes with it bolt to the crossmember or to the tranny?
What mods if any needed to be done to make it work/fit?
How is that shifter to operate?
What gears are your guys running and what are your rpm's at 70 mph?
Where did get it from and how was the company to deal with?
Any other input is welcome and very appreciated!
Thanks in advance!
BTW I am trying to keep the cost down so not really interested in the 6 speed.
Thanks in advance!
Re: Richmond 5 speed users please step inside. (Fevre)
I have a Richmond 5-speed in my Cobra replica, so the only thing I can comment on is the ease of shifting. It took me several thousand miles to get accustomed to the shifter. During that time I frequently selected 5th instead of 3rd and vice versa. I much preferred my M-21 with a Hurst shifter. However, now that I am very practiced with the Richmond, the problem of finding the right gear has gone away. And it is very nice to be able to cruise at 2400 RPM instead of 3000.
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
The 5 speed is a 1:1 final drive ratio, but it has a lower first gear- so you can use 3:08's or 3:36's for rear gears.
It is the same length o/a as the Muncie or T-10. The shifter is included, and bolts to the side like the T-10 and Muncie. The yoke is a TH400, so it will fit a stock length driveshaft. I didn't do any hacking to install the Richmond 6 speed, so I don't think there's a lot to it, modification-wise...
:yesnod: :chevy :chevy :yesnod:
Re: Richmond 5 speed users please step inside. (MassVette)
In addition to what Massvette said: You will have to change the yoke...TH400 is the correct one to use, though I understand you can also get a 10 tooth spline input shaft on the R5S...you may want to consider this option. If you plan to install the tranny by itself, you will have to remove the rear tailshaft housing to clear the crossmember. Once bolted in place, the rear housing can be bolted back. You may or may not have to cut the ends off the shift rods, mine were way too long. Other than that, no modifications to the tunnel or to the crossmember are required, and the shifter is in the stock hole.
Re: Richmond 5 speed users please step inside. (GDaina)
Thanks for the input, I finally ran the math on the rpm's with the 3.08 and 1:1 final drive and it is a little higher than I had hoped compared to a .68 OD with my 3.70 rear now but not enough to cross the Richmond off my list. It does sound like a more straight forward install compared to doing a TKO install and with all the minor problems and delays with the Keisler unit I do not want to go that route.
I can't comment on the wait because I bought the kit from a forum member who decided to go with a 6 speed. The install so far has been a breeze. I did elect to cut the cross member but other than that it has been a very easy install. I can't wait to give it a try. BTW I also have 3.70 gears which comes out to a 2.51 final drive.
Re: Richmond 5 speed users please step inside. (Gordonm)
Enjoy it! :steering:
Fevre,
Regarding the original topic of the Richmond 5 speed. I just bought a used one from a Forum member. This seem like the best way to go since I still had the original 3.08 gears in the rear so the 3.27 first will great and the 5th 1 to 1 matches the 3.08 gear for highway drives.
I looked at many different options before th install:
1) Richmond 5 speed is the closest bolt unit. Negatives are no shifter or reverse light kit with the trans. Hurst shifter is $300 and Long is $500. making reverse light bracket and swtch myself.
2) Richmond 6 speed comes with Long shifter and reverse light kit. Cost $1000 more than 5 spedd Richmond. Also may need more mods to mount since the 6 speed is in the rear housing.
3) Tremec is an option but 5 and 6th are overdrives. Yes the 1st gear is lower than the normal 4 speeds, but the gear spread is much bigger than Richmond units. Could be a much bigger RPM drop between gears. Cost is up there and requires more mods. Integral shifter is an improvement over Richmond external.
So far I have done a trial fit to the schatter shield on the bench. Next is to pull the old auto unit out.
Dave
Dave
Re: Richmond 5 speed users please step inside. (DaveL82)
For some reason I thought both the 5 and 6 speeds came with shifters so the price has creeped up another $300-500 for the richmond 5 speed. :(
Talk to the teckkies at Richmond Gear.
http://www.richmondgear.com
They were very helpful to me when I was figuring out the install. And it's free-
:yesnod:
BTW, here's a shot of the ROD 6 install in the 79-
snug, but fit fine...........
good luck!
:yesnod:
good luck!
My down the road goal is a 5 speed 1-1 5th gear. But my rear gear choice would be a 2.73 maybe even 2.56 Right now in 700R4 over drive I end up with @2.86 gearing and I would like to drop another few hundred rpm. Because most of my freeway driving is posted at 75 mph and I'm always somewhat over that speed. I just hate driving for hundred of miles at over 3000 rpm
Re: Richmond 5 speed users please step inside. (gkull)
Also sounds like I might as well get a richmond 6 speed with the OD gear and the shifter is included. Guess it is better to have too many choices instead of too few.
[Modified by Fevre, 10:42 AM 3/2/2004]
Re: Richmond 5 speed users please step inside. (SHAKERATTLEROLL)
All that I know is what's on that site. I believe that it's a GM T56 that's been beefed up with some select Viper internals. If you're interested, call D&D. The guys that I have talked to are very personable and willing to talk to you. I need a T56 for my LS1, so I'll probably end up going up there the end of this week.
I ran a RG 5-spd from 93-98 when the rebuild started using a 3.08 rear end. It transformed the car into something even better, and I certainly like driving it more than the BW Super T-10. Cruising, the tach showed 2950 at 70, but my tach was ax. 300 revs high, compared to spreadsheet calculators. It should have been near 2600 at 70 with 3.08's and P225R70-15 tires. Best change I made to the car from the T-10/3.70 original combination.
I have a RG 6-spd for the rebuild, but since we swapped the tweaked ZZ4 for a crate LS6, I need to get lower into the LS6's econo range after talking to Dave Hill at Carlyle. I will sell it and go with a 3.90 rear and T-56 so I can cruise between 1600-1800 revs at 63-72 respectively. That should yield 30+ mpg on the cruise control on long trips.
The RG 6-spd with Long Shifter (never did like the Hurst on the 5-speed) is available for sale. Unfortunately, my email dissolves this weekend due to a move, but you can try the cell at 352-425-0891 if interested.
Spike
Spike
Re: Richmond 5 speed users please step inside. (spikezz4)
I installed a Richmond Street 5-speed, a Long shifter and a 3.08 posi in my 57 in June, 2002. Hopped in it the next night and drove from FL to the NCM nonstop overnight (I was the 57 alternate for the Motorama). Five weeks later I drove to Monterey, CA and back. Since then I've also driven to Flint MI last summer. All told over 14000 miles and not one problem with that stuff. Since my tach isn't the most accurate of instruments I'm guessing that the new setup (I replaced a Muncie and a 3.70 posi that wasn't posiing well...) loses about 800 rpm at highway speeds. My mpg is right around 20. 1st through 4th gears feel quite like the old Muncie/3.70; then there's another gear-Wow!
It's fun to do this:
