1 Piece top for the "T"'s?
Re: 1 Piece top for the "T"'s? (CAJUN ZZ4)
I have seen a few vendors that offer a one-piece acrylic or glass top that replaces original t-tops - check Mid America, Eckler's, etc.
If your T-tops are leaking, you should first try identifying the leak source and/or replacing the weatherstripping (unless your primary objective is to get a single piece top).
Location: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Received 2,239 Likes
Re: 1 Piece top for the "T"'s? (Master Ho)
Thomspon Astro Top makes them. I have a couple of good used ones. Make offer?
[Modified by Corvette ED, 6:48 PM 2/29/2004]
Thomspon Asto Top makes them. I have a couple of good used ones. Make offer?
Elite Torch Red Member
Don't do it, especially from Thompsons.
1st question, where do you store it when you remove it, won't fit inside the car. Don't want to leave it home in case it rains.
BTW, this belongs in the "General" section.
Re: 1 Piece top for the "T"'s? (Mr Mojo)
Mr. Mojo - 2 things.....
1 - I have one and it fits inside my car, of course my car is not filled up with speakers and such behind the seats......
2 - Why doesn't this post belong here?
Re: 1 Piece top for the "T"'s? (KenSny)
I'm interested in knowing why you are negative on these tops as well. I'm a bit taller than average and was considering one for the extra "top end". What problems are you aware of regarding Thompson's or any other one piece tops? Thanks.
Re: 1 Piece top for the "T"'s? (Steve's74)
I had the pleasure of owning one for 9 months. I was also able to fit it in the back even with a sub box. It did prevent leaks but added to the wind noise factor. At the 9 month mark it just snapped in half while I was holding it from one side. Oh well it was only money :(
Re: 1 Piece top for the "T"'s? (IT STINGS)
Prior to going to the paint shop my astro top had been on the car for more than a year with zero problems. A lot of people knock these tops, but many of them have never owned one.
[Modified by fauxrs, 5:24 PM 3/8/2004]
Well I was shopping for one as my t-tops leak, and I Corvette Central had one of those. But then I called them to see if it will fit in the back and they were like yeah. So I asked them what the's measurements as I want to be 100% sure b4 I ordered it and the guy was like oh I have no idea. SO needless to say i didn't buy it. I don't think it will fit in the back as the t-tops sit on top of one another and in the back and the other one I just don't think would fit right. :skep:
