T-Arm GP from Van Steel
Premium Supporting Vendor
I've received a few request from forum members to do a GP for trailing arms. Here is what I have to offer.
Lets start w/Bare Offset T-Arms
Regular Price is $389.99 for the set (L & R)
Forum Price is $330.00 for the set (L & R)
With the bare offset t-arms you will receive both R & L Offset T-Arms w/poly bushings, spring retaining washer, bolts, nuts, lock washers and cotter pins to mount them to the bearing assemblies. We do not sell offsets unless they are in pairs.
If you want Double Offset T-Arms add $20
Complete Offset T-arms
Regular Price is $1169.97 core $600/$300 per side
Forum Price is $ 990.00 core $390/$195 per side
This price is for both sides. We do not sell offsets unless they are sold in pairs. You will receive
New Offset T-Arms powder coated black w/poly bushings
New Backing Plates(silver or gold depending on year or your prefrence)
New bearings, seals, races
New SS parking brake hardware
New Shoes
NEW SPINDLES
NEW ROTORS
Built to Van Steel's standards
If you want Complete Double Offsets add $20
Bare T-Arms
Regular Price is $195.99
Forum Price is $155.00
This price is per arm not pairs. These T-Arms come powder coated black w/Rubber bushings, spring retaining washer, bolts, nuts, lock washers.
Complete T-Arm Assemblies
Regular price is $389.99 per side core $300
Forum price is $330.00 per side core $300
Refurbished T-Arm powder coated w/rubber bushings and spring retaining washer
New Backing Plate(silver or gold depending on year or your prefrence)
New Shoes
NEW SPINDLES
NEW ROTORS
In order to receive full credit back on cores, your core MUST BE reuseable. If any of your parts are bad, it will be deducted from your core refund. Here's a breakdown of what will be deducted if it's bad.
Bad T-arm - $100. if it's bent, not twisted, and we can repair it than it will be $40.
Bad Spindle - $100
Bad Bearing Support - $120
Bad Caliper Mount Bracket - $75. If we can repair than it will be $40. If the threads are stripped or the bracket is bent and we can fix it than it's considered repairable. If the brakcet is broken or your bolt holes are elongated to where we can not put a heli coil in it than it's bad and you will lose $75.
Of course you will receive FREE SHIPPING on all orders. Note that all complete assemblies are coming w/brand new spindles and rotors.
If you have any questions please feel free to ask away. You can contact me direct at
Dan Dorsett
vansteel@vansteel.com
800-418-5397 inside US
727-561-9199 outside US
All orders shipped outside US will have to pay for shipping. You pay what we pay.
If I missed anything I will try to cover it the best I can on this thread.
New Shoes
NEW SPINDLES
NEW ROTORS
Bare T-Arms
New Shoes
NEW SPINDLES
NEW ROTORS
Bad Spindle - $100
Dan Dorsett
Re: T-Arm GP from Van Steel (Van Steel)
I don't see a price for Bare 'standard' Trailing Arms... Am NOT interested in poly or off-set but I do need to replace the bushings on mine and don't mind going ahead and just replacing the arms. If available, would they come with the four bolts to mount the bearing assemblies?
I have cores from about 5 years back ... ????
Don't worry, I don't wanna return them. Spare parts ... or maybe 4 sale some day.
Re: T-Arm GP from Van Steel (TedH)
Hey Ted ... lots in there, you missed it.
QUOTE:
Bare T-Arms
:seeya
QUOTE:
Bare T-Arms
:seeya
St. Jude Donor '08
Re: T-Arm GP from Van Steel (love to drive)
I was wondering the same. How wide of a wheel can you run in the back with the double offset? (I have near brand new heavy duty trailing arms on mine, but when i want to goto a wider wheel I will most likely go for offsets or double offsets if they are worth the extra 20 bucks :) )
Please pardon my ignorance but what is a double offset T-arm?
Re: T-Arm GP from Van Steel (hermit)
Double offsets are pretty much the same as single offsets except you will need a 1" shorten spring. Most of the time when someone is running a double offset they are notching the frame to run a much wider rim and tire and they are more than likely drag racing. For street use just go w/a single offset and you'll be OK.
Dan
Dan
How about a package deal with off-set T/A's, coilovers and a larger swaybar for the front, smart struts for the rear.
I already ordered a TRW 315 spring for the back and I have a stock bushing set for the front A-arms. I'm not sure what else I need though.
I guess I could do without the struts for right now. Oh, I think I would need shocks for the back too. :)
Jeff
I have a set of your offset arms in my car now.When I put them in the bushing hole the bolt goes thru seems that the hole is bigger than the bolt.Is there a sleeve that is supposed to be in there,ever since then i now have wheel hop badly.I also have the traction bar but it didn't make a difference.If I'm missing something do you sell the sleeves???? Or is it the poly bushings that are too hard maybe the rubber one absorb the shock the better when launching???
Dan,
Thanks for coming through for us. I need the complete T-Arm assemblies for both sides, no offset.
Questions:
Any idea how much shipping the cores back will cost? I assume we just re-use your packaging.
I have poly bushings from VBP that came with their performance plus package. Would you install those if I sent them to you first?
What's your turn around time?
How do I proceed with the order? :cheers:
Questions:
Location: At the end of 2 big long black marks on #2 Sideroad and Walkers Line.
I am still a little bit new at all this stuff... So please bare with my questions.
I am interested in this deal since I am planning on redoing my suspension before the spring.
I am looking at your Front and Rear Poly Super Kit and I got a set of KYB Gas-A-Just shocks for Christmas.
So the question is...
Are the Complete T-Arm Assemblies complete replacements (i.e. I just take mine out, and put yours in...) Mine have some pretty good squeaks, and I don't think I have the skill to actually rebuild them my self?
Also I remember talking to somebody at your office, and they said if I got the Poly kit at the same time you could put the poly stuff on for me.
I am also wondering about the length of time to send you the cores. Mine are still on my car... :-) but I don't think I want to let this group purchase pass. It is finally one that I can make use of.
Thanks in advance.
chris.
Thanks in advance.
chris.
