aftermarket gauges in c3
Re: aftermarket gauges in c3 (1yy07)
Don't have the link.. but here are my aftermarket gauges:
Use electric for the gas gauge- all you have to do is hook up the existing wire-it will use the stock sender.
Use mechanical or electric for the oil pressure gauge-I used mechnical- just a fitting on the back of the block or the electric will hook up to the existing wiring.
Use an electric(of course) for the voltmeter-stock wire hookup.
Use an electric for the water- use the sender that they include with the kit.
Some of us have installed an air/fuel ratio meter to replace the clock.
are they electric or mechanical?
Re: aftermarket gauges in c3 (LakotasRose)
You might want to check here also http://earchitect.50megs.com/corvette/gauge.htm
