4 speed crossmember welded to frame
Why is this? Does anyone find this as annoying as me? Anybody ever 'converted' one to bolt in style? :confused:
Re: 4 speed crossmember welded to frame (PRESSURERAT)
Yeah, I've thought about it too. Thought it'd be cheaper for GM just to make ONE style of frame for any given year, instead of two. '80 & '81s were this way. They had the removable crossmember whether the car was an automatic OR 4spd.
Re: 4 speed crossmember welded to frame (Paul Borowski)
Its a maintenance issue.
The manual tranny can be removed with out removing the crossmember. The automatic requires the removable crossmember or engine removal for transmission removal.
I am also thinking frame torsional rigidity would be significantly increased with a welded in crossmember.
I don't remember anyone doing a retrofit..... but a custom job would be much easier that retrofitting a stock auto crossmember.
do a search on member fauxrs, he and a few others have moded their crossmembers to make them removable and he has posted some nice pics of it.
Re: 4 speed crossmember welded to frame (Fevre)
Indeed When in installed a TKO 5 speed I changed my crossmember to be bolted in.
This is the modded x-member installed with four (4) 1/2" diameter machine bolts - way overkill on bolt size but certainly it helps to regain any rigidity lost - I havent noticed any increased flex in the car.
This is the x-member out of the car - the plates are 10 ga. steel bent in a horseshoe shape to fully capture the stubs of the frame - my concept was that this would protect the cut ends from capturing water while driving.
[Modified by fauxrs, 7:43 AM 10/21/2003]
[Modified by fauxrs, 5:13 PM 10/21/2003]
[Modified by fauxrs, 5:14 PM 10/21/2003]
Re: 4 speed crossmember welded to frame (fauxrs)
Thanks for all the replies!! You TKO guys, did you buy a 'kit' or did you piece them together?
I cut out mine after adamantly stating I never would. I used a sawsall with 18 point blade at very slow speed. It cut through like butter.
I welded up 2 pieces of angle iron on each side. I measured for and drilled 2 small holes in the ends. I then put the newly welded crossmember in its intended place and drilled into the box frame with the same small diameter drill. Once removed, it was now easy to drill all the holes with a 1/2" drill making for perfect alignment.
I cut a length of black pipe to fit tightly between the two holes inside of the box frame. I then tack welded them. This allows me to really torque down on the 1/2" bolts I will use without crushing the box frame.
Chuck
Chuck
Re: 4 speed crossmember welded to frame (Chuck Harmon)
I spoke to a factory engineer once and he said it was for strength. It also made it harder to steal the transmission.
Annoying, heck yeah :smash: I saw it an opportunity to cut mine out when I installed my TKO. At that point with sawzall in hand, I knew there would never be anything I'd be afraid to try with my car :p:
[Modified by SmokedTires, 4:03 PM 10/21/2003]
Mine was pieced together - there is a kit from Kiesler, which has recieved good reviews from those that have installed it. The kit is a good deal more expensive than piecing it together, but it offers certain advantages.
This site outlines my install http://earchitect.50megs.com/corvette/gearedup.htm
Re: 4 speed crossmember welded to frame (markdtn)
