C3 7qt oil pan that will fit?
5th Gear
I have tried a couple of different 7qt oil pans for my 78 corvette. However, they all seem to be htting the "big bar thingy" from the steering unit. (rubs about 6 inches back from the front of the oil pan and about 4.5 inches deep from the bottom of the block) Is there a known large volume oil pan that will fit?
[Modified by Azmodeus, 3:51 PM 10/20/2003]
Re: C3 7qt oil pan that will fit? (Azmodeus)
1st post, welcome. I have a stock pan, but others on the site have 7 quart pans. You should get an answer soon.
:seeya
:seeya
Received 1,874 Likes
2017 C2 of Year Finalist
First off...let me welcome you to our world too! You're going to like it here!
Is it still small block in there? If so I may have to defer to some other folks. I can help you with big block stuff though!
See ya,
JIM
See ya,
JIM
5th Gear
Re: C3 7qt oil pan that will fit? (427Hotrod)
Yes, have a 400ci sbc in it.
I'll try and update my profile with a pic once I get her out of the shop.. :)
[Modified by Azmodeus, 5:27 PM 10/20/2003]
A 6 qt pan with the long filter gets you almost 7 qts total, close enough? Are you running super high rpm's or racing it? Gotta love a 400sb. :yesnod:
Re: C3 7qt oil pan that will fit? (Fevre)
Check out Moroso that's what I have with side kickouts, should fit. :D
5th Gear
Re: C3 7qt oil pan that will fit? (The Money Pit)
Excellent. I'll give it a try.
Is that the one listed above as:
"Get the xxx191 with the scraper and windage tray"
No scraper in this one.I got a kit from Summit that included the pump with welded pickup and the pan for like $175.It does have a trap door to control some oil movement,but no scraper or screen.
Azmodeus - As you can see from the money pits picture. The knuckle joint where the ram attches to the steering arm is the high point.
I custom made my own 1/2 inch thick block out of aluminum and spaced the ram down where it attaches to the drivers side frame. I then had enough space to clear my 8 quart road racing pan built for up to 4 inch stroker small blocks.
A fellow forum member I know ground the top of the joint for added clearance :seeya
I'm using the Moroso 20191 with my 406. It has trapdoor/scraper/tray.
http://store.summitracing.com/partde...rt=MOR%2D20191
$178.95
$178.95
5th Gear
Re: C3 7qt oil pan that will fit? (C3 Shark Tank)
C3 Shark Tank,
From your pic, it looks like you bent up the oil pan to have enough clearance?
I'm getting the conclusion that there is not one that fits without modification to the pan or the arm?
C6 the C5 of tomorrow
Looks like the same pan to me
I have (had) power steering too, fits fine
