[PIC] My new Convro Pros...
The rear ones are 15 x 8.5 with 3.375 backspacing and the front ones are 15 x 4 with 1.3/4 inch backspacing..
Senior Member since 1492
Re: [PIC] My new Convro Pros... (GrandSportC3)
:cool: :cheers: The center's look pretty flat. They should clear the calipers.
Re: [PIC] My new Convro Pros... (8T1-7T9 BIONIC VETTE)
Sweet looking rims.......Will you have to use spacers?
Those will look nice, is that a weight I see on the outside ?
Re: [PIC] My new Convro Pros... (79VetteMike)
Please post pictures with them on the car......
Where did you get them and please provide part numbers..... :thumbs:
Re: [PIC] My new Convro Pros... (MotorHead)
I will have the weights placed on the inside once I put tires on them...
The front 15 x 4 with 1 3/4 inch backspacing is Centerline Part number: 005401547
The rear ones are part number: 005853547
They might stick out a little bit on a stock C3.. I have 1 inch flares and they fit just perfect..
I will have my Mickey Thompson ET Streets installed on the rear ones and some 165R15 tires on the front runners...
