What is exterior code 14L on a '74?
I went out to look at a '74 #s match LS4 coupe for sale today and it had a exterior trim code of "14L" ... the car is black, but it's obvious it started as a silver mist/silver leather car.
Is 14L actually "914 'Late'?"
Thanks,
Sam
Thanks,
Sam
Re: What is exterior code 14L on a '74? (sammyb)
The "L" is for "Lower" as opposed to "Upper" for two-tone paint schemes. The 9 was dropped. Since the Corvette was not offered in a two-tone paint scheme, the L paint code is the only one showing.
I believe this started in 1974. And I believe it's correct, but others will chime in I'm sure. I don't have my black book handy to look up the 14 code.
Re: What is exterior code 14L on a '74? (mayberg)
Location: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In IV Veteran
Cruise-In VI Veteran
SECONDARY COLOR, XTERIOR, LT GRAY MET (92)
The 14L actually refers to the RPO code. The color I believe is 92 (light gray metallic)
[Modified by SnoDrgn, 2:22 PM 10/20/2003]
Re: What is exterior code 14L on a '74? (SnoDrgn)
