When removing your engine........What did you detail and paint the bay with
Just curious.......I really want to clean everything up well when I pull the original motor and drop in the stroker.........Any tips/
Re: When removing your engine........What did you detail and paint the bay with (Alwyn678)
Clean with liberal amounts of Simple Green. Wipe down eveything with lacquer thinner, the follow up with a wipe down of Prep-Sol. Then paint the engine bay with John Deere Blitz Black spraypaint. It's a nice eggshell finish black that lays down really well and is very durable. Plus it's nearly an exact match for the original blackout paint that was use in St Louis.
Shannon
Shannon
C6 the C5 of tomorrow
Re: When removing your engine........What did you detail and paint the bay with (nastee383)
clean degrease with lacquer thinner, then degreaser, then PPG Epoxy primer then PPG black / viper yellow / viper red / clearcoat.
[Modified by 427V8, 11:13 PM 10/18/2003]
St. Jude Contributor
Re: When removing your engine........What did you detail and paint the bay with (427V8)
I'm going to paint my engine and bay this spring, I think i'm going to use paint from the eastwood co. GOOD LUCK
CHUCK :seeya
CHUCK :seeya
Cruise-In IV Veteran
Re: When removing your engine........What did you detail and paint the bay with (327shp)
por 15 chassis black for the frame/cross member for me.. then GM wheel well black paint.. (you can get it at your local chevy dealer)
