Trickle Charger?
Old 10-17-2003, 10:01 AM
flynhi
flynhi's Avatar
Default Trickle Charger?
What's the consensus on the best/most reliable trickle charger for batteries stored for several months?
Old 10-17-2003, 10:15 AM
Bobchad
Bobchad's Avatar
Default Re: Trickle Charger? (flynhi)
I got one at Costco for about $40. Charges at 2 amps, 12 amps or has a starter blast and has an automatic and manual setting. It has protection circuitry in it that will disengage the charger if necessary.
It is currently hooked to the car charging at 2 amps. It indicates with a green light that the battery is charged and with a meter that no juice is being applied to the battery currently.
Old 10-17-2003, 10:33 AM
cicch95
cicch95's Avatar
Finalist 2020 C4 of the Year - Unmodified
Default Re: Trickle Charger? (Bobchad)
The "Battery Tender" works well.
-Rick
Old 10-17-2003, 10:35 AM
BlueL36
BlueL36's Avatar
Cruise-In V Veteran
Cruise-In VI Veteran
I think I have the same type. Made by a company called Schumacher. The son with same last name is big in drag racing.
Old 10-17-2003, 10:40 AM
sammyb
sammyb's Avatar
Default Re: Trickle Charger? (BlueL36)
I have a Schumacher and yesterday it never shut off on 2amp trickle, so when I went outside late last night, I could hear my Optima Red Top sizzling (even after I took off the charger.)
I'll check today, but I think the battery is toasted.
Old 10-17-2003, 11:29 AM
71'AirStrike
71'AirStrike's Avatar
Default Re: Trickle Charger? (sammyb)
check the battery for cracks, swelling and leaks in the casing. Optima's are nice but the only drawback is if there is overcharging, or it need to be re-charged raplidly from a depleted state there is no where for the excess gas to excape to.
It may rupture
cheers
chad
Old 10-17-2003, 04:57 PM
gq82
gq82's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Default Re: Trickle Charger? (cicch95)
-Rick
:iagree:
Old 10-17-2003, 05:04 PM
Chuck Gongloff
Support Corvetteforum!
Chuck Gongloff's Avatar
Default Re: Trickle Charger? (gq82)
Don't know if my impression is 100% correct, but I believe a "trickle" charger continuously charges the battery, whereas a "float" charger will charge up to the prescribed voltage, then shut off.....then kick on again when the battery voltage drops.
I use float chargers made by Sure Charge. Bought them at my local battery warehouse. Chuck
To Trickle Charger?
Quick Reply: Trickle Charger?
