OK guys I have a hard question Help!
Ok I asked earlier about engine block numbers I have the absolute correct numbers because I have seen them for myself The stamping on the pad in front is F I I I 3 S Tha casting number on the back of the block is 3782870 the cyl head casting number is 3795896 If you guys can help me I would greatly appreciate it!!! Thanks Robbie
Re: OK guys I have a hard question Help! (Love My 72 and 77)
The 870 block is a 327 block used in Corvettes and other Chevrolets from 62-65. The F 1113 S translates partially as "Flint, Nov. 13" The S is a passenger car code used with Powerglide transmissions. Can't tell you exactly which years. What is the casting date of the block located back behind the distributor? Should be something like A 1 3 Jan 1, 1963 etc. Chuck
