What about this setup?
Old 10-16-2003, 07:26 PM
homedawg247
homedawg247's Avatar
Default What about this setup?
i have a 78 Vette, took the stock block bored .030 over, stock rods and crank, new zollner pistons, new comp roller cam, roller lifters, roller rockers, stock heads, new springs, edelbrock #2101 alum. intake, edelbrock 600 cfm electric choke carb, proform dist. w 50,000 volt in-cap coil, new oil pump,
i was wondering 1st what kinda power should i b making? 2. where can i find the tranny(auto) lines going to the radiator. 3. how do i set the lash on the rockers, the lifters have springs to pump the oil up on the rockers, i ahve heard tons of ways to set them and was wondering what is the "right" or "best" way to set them
Thanks
-Johno
Old 10-16-2003, 07:43 PM
redwingvette
Support Corvetteforum!
redwingvette's Avatar
Default Re: What about this setup? (homedawg247)
The cam specs are needed to make any quess as to how much power you can expect. The stock heads will make it hard fo you to see much more than 300HP. You can get the trans cooling lines from most of the suppliers or you can get brake lines from a local parts store and bend them yourself.
Old 10-16-2003, 09:21 PM
homedawg247
Default Re: What about this setup? (redwingvette)
card looks exaclty like this:
___________________Intake_____Exhaust
Valve Adjustment____HYD__HYD
Gross Valve Lift______.48____.495
Duration at
___.006__Tappet Lift____264__________270
Valve Timing____Open______Close
AT____.006_Int____26_BTDC___58 ABDC
___________Exh___69_BBDC___21 ATDC
These specs are for cam installed
at__106___intake__center__line
_________________Intake______Exhaust
Duration_at_.050____212_________218
Lobe Lift___________.3250_______.3300
Lobe Separation_____110
[Modified by homedawg247, 2:29 AM 10/17/2003]
[Modified by homedawg247, 2:33 AM 10/17/2003]
To What about this setup?
Quick Reply: What about this setup?
