paging GENE...
paging GENE...
i wanted to ask you about my power door locks...
i am not reinstalling the pass side lock switch...
should i just tape up the harness inside the door or can i somehow disconnect it and remove the wires going there?
how would you do this?
also...check out my other thread again please, i posted a couple of questions there for you...thanx... :)
Re: paging GENE... (SIGNGUY)
Yeh, well depending on the nature of the connector, some electrical tape held with a tie wrap on it is a good idea....the tie wrap means the heat will not let the tape unwrap....
GENE
GENE
