More TT2 questions, 18x10 w/5" BS?
I promise no more questions on wheels and tires after this! (Maybe!).
Anyone running or know if TT2s, 18x10s with 5” backspacing will fit on the rear of a 69? And yes I am using offset trailing arms.
And if someone is, what size tire?
Thanks again, Eric.
Thanks again, Eric.
Re: More TT2 questions, 18x10 w/5" BS? (EricU)
Dewcustom's car is set-up with these:
He stated with these tires:
-fronts 18x8 w/ 4.25 backspace and 255/45s
-rears 18x10 w/ 5.5 backspace and 295/45s
-offset trailling arms installed
-modified the frame in order to fit them in
I suppose if you wanted less backspacing, you could get away with possibly not having to mod the frame, but you might have teh wheels sticking out of the fender a little.
Brent...
Brent...
Location: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
Re: More TT2 questions, 18x10 w/5" BS? (MN-Brent)
Go to www.corvetteforum.net/c3/dshrack and look at the '81 with a set of Centerline 806's with a 5"BS and no spacers. dshrack has 285/40/ZR17 Firehawk SZ50s mounted on all four.
Wheels/Tires:
(4) 17”x9.5” Centerline Billet Aluminum Wheels: Series 806, 5” Backspacing, 5x4.75” Bolt Pattern,
18 lbs/wheel
(4) 285/40ZR17 Firestone SZ50 EP Tires: 330AA, 26” Overall Dia., 11.5” Overall Width, 9.8” Tread Width
Looks awfully good to me!
I still have reservations about orderiing my tires as well as everyone else. This has been discussed to death and we do need a good evaluation done to see what will and will not fit with the OST/a's in th erear and what will work in front.
Anyone else have any good info? Jim
[Modified by PROSOUTH, 8:46 PM 10/15/2003]
Wheels/Tires:
18 lbs/wheel
OK, I lied! One more question.
"-rears 18x10 w/ 5.5 backspace and 295/45s
-modified the frame in order to fit them in"
Anyone know what he did to modify the frame?
Thanks, Eric.
Thanks, Eric.
Thanks, Eric.
Thanks, Eric.
