wide rear tires
wide rear tires
what is the widest tires you have seen on a c-3? i have a 77 and was wondering if i could go wider than the 225s on it now
thanks
thanks
Re: wide rear tires (ray77vette)
I have 255 's on the rear!
295's fit too :D
Where's Norval ? :lol:
[Modified by MotorHead, 7:41 PM 10/15/2003]
Re: wide rear tires (MotorHead)
295's fit too :D
Stock rims and trailing arms, you have to relocate the e brake bracket
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '03
325's fit too, but ain't nothin' stock! :D
I had MT 12.5 x 28 x 15 sportsman pro wrinkle walls on for a while, then 295's then the present 305's x 50 x 15. I could go a little bigger but I can not find 15 inch radials and not drag radials. I do have alot of work done to the wheel well.
IN this shot both the upper and lower strut rods are removed so the tire is hanging out at the top. The wheel is resting on the lower strut.
Re: wide rear tires (norvalwilhelm)
Norval, UNFARE< UNFARE>>>>>you got a machine shop....no fare...you play in another league...us mortal vette owners have a bit of difficulty fitting anything even CLOSE to that under our cars.....
well maybe a 275/50/17, but....humm.....maybe IF....humm....gotta go talk to my welding buddy....next year....
GENE
GENE
Re: wide rear tires (corvettemaster)
I'm seriously thinking about 29x15.50R-16 Only ones available in that size are Hoosier Pro Street Radials, they're available in 15 & 17" insane wide sizes too :D
Norval, do you have pics of how it looked w/ the wrinkle walls?
[Modified by Twin_Turbo, 4:37 PM 10/16/2003]
