rear end oil (grease) and aditive recomendations please???
im sure this has been addressed here before so i appologize for asking...but,
what kind is the best?
how much of it?
how much of it?
Re: rear end oil (grease) and aditive recomendations please??? (SIGNGUY)
I like to use the GM stuff both the additive and the dino oil. Use 2 bottles of the additive and fill the housing until the oil is weeping out the fill hole-about 2 qts if empty.Be sure the rear end is level.
Gary
Gary
i would recommend using the GM additive. When I did my rear i used gear oil that said it ws good for posi's but within the first week or two it started making clunking noises. I put in two bottles of the GM additive (I think they were 8 oz. each) and haven't had a problem since. When you put the additive in go to an empty parking lot and do some figure 8's to work it in. It's been quite a few years since I did mine and everything's been fine so far. Good luck.
Re: rear end oil (vettfixr)
I too used the GM stuff in the 70. When I had my 79, I put the Mobil 1 stuff in there. Both work great.
I use Redline HD synthetic gear lube in all my applications, both transmissions and differentials with excellent results. A bit pricey, but effective.
Hans
Hans
I used 1 bottle of the GM additive and filled it up with Mobil 1 gear lube. No problems at all. Some say 2 bottles of the GM goo, but I didn't find that necessary so why waste it.
The directions on the GM bottle and GM shop manual said (1).
