Inside Rear Window Moulding?
I replaced my broken inside rear window moulding with a new one from Corvette America. The moulding has a gap between it and all around the rear window and does not even touch the rear glass as I would have expected. Is this normal for a 1973 C3 Coupe? Also there is a hole in the bottom middle of the moulding where a screw is supposed to go. The old one did not have this and there is no place to screw into. Any good way to make a screw anchor in the fiberglass?
Thanks
Thanks
Location: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In IV Veteran
Cruise-In VI Veteran
Re: Inside Rear Window Moulding? (aardvark)
Mines still original from 74 I think and fits like crap (pretty much the same as you're explaining) although 99% of the replacemnt interior parts I bought from Corvette America were garbage. :leaving:
