Intake and Header Torque?
Re: Intake and Header Torque? (blunsford)
Surely someone knows how much to torque these babies down????? Haynes manual is worthless, it just says "torque to specs". Duh
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '03
I believe standard is 30 ft-lbs in intake bolts and 20 ft-lbs on exhaust.
Haynes page 2A-2
[Modified by Rolling Thunder, 10:57 PM 10/13/2003]
Haynes page 2A-2
Re: Intake and Header Torque? (Rolling Thunder)
Intake - the 30lb/ft is for iron manifold to iron heads. When I looked on the Edlebrock site all I found (last year) was 25lb/ft which is what they had for performer to aluminum heads. I doubt if 30lb/ft is going to warp the intake if you are using iron heads, however the bolt head might cut into the aluminum a little anyway.
