Timing & heating
Timing & heating
Can timing being off, befor/after, cause a engine to heat?
Background.
I just got my first Corvette. A 77, not the original engine & no history.
The speedo needs to read 90 to keep up with traffic doing 70.
The tack isn't working. I hope to get to it today.
With the speedo, up to 70, the temp is 180, at 90 - 210. .
The temp goes to 180 & stops rising at slower speeds, so the thermostat is working right.
5 to 10 miles at 90 the temp is 210 & does not get any higher.
Getting off the interstate, on the 55 roads, the temp drops to 180 in about 5 miles.
The car pissed when I did, at a rest stop, without the 5 miles on 55 roads.
It may have been over full. It is at the right level now.
It does not get hot on short runs to 120. Tests runs. :-)
I checked the timing yesterday. It was about TDC, or later. It is now 10 before. ??
I haven't had the car on the interstate since the timing change.
There is a new looking 1 core radiator in the car. Is it big enough, or do I need a 3 core?
Any thoughts on the above will be appreciated.
Lee Smith
Re: Timing & heating (Lee Smith)
Low timing will cause high heat. Check, Vac. Advance, and centrfical advance for proper operation. 10 deg. inital is plenty.
1 core should be plenty for your engine. I am thinking fan clutch could possibly be your problem.
Re: Timing & heating (gmcclurg)
Thanks all.
The new alu 1 cores look very thin when I am use to the 3-4 core copper.
I will find out if I get a 5-10 mile drive in this week.
[Modified by Lee Smith, 10:59 AM 10/14/2003]
Re: Timing & heating (LAvetteman)
Fan should sound like a hurricane when engaged. Also make sure your spoiler is in place- makes a big difference for some folks.
