Using C5 wheels on a C3
Old 10-11-2003, 11:55 AM
75 BBC Stingray
75 BBC Stingray's Avatar
Default Using C5 wheels on a C3
I'm looking for opinions and experiences here. I know from the post on 17" wheels, that at least two forum members have gone this route. Also from reading the BBfH series of articles, that it was done there as well.
My thoughts are these: I want 17 inch (or 17/18 inch combo) on my car. While I like the TTII's, and some of the other aftermarket wheels I've seen, the price is pretty high (I guess I don't like them that much... So a reasonable alternative is to pick up a set of factory wheels. I've been scanning Ebay, and it seems like the 95-97 style (sometimes called ZR-1) are going for as cheap as $300. This is the 5-spoke style that has wide rectangular spokes with a notch in the face at the rim. I also like the rounded 5 spoke design (there are several, I know, but I'm partial to the wider spoked versions).
That would be 17X8.5 in the front and 18X9.5 in the back. My tire choice would be 255-50-R17 in the front, and 295-45-R18 in the back. This would give me a sidewall of 5.0 to 5.25 on both the front and back. I realize that I would need adapters to fit these wheels. I also realize that the gears for the speedo would need to be different do to the larger rear wheel.
So what do you guys think???
Old 10-11-2003, 12:05 PM
Guru_4_hire
Guru_4_hire's Avatar
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Using C5 wheels on a C3 (75 BBC Stingray)
I was gonna run some 17"/18" TT2s some custom offset and ZL1 flares.
295s in the rear and 235 or 245 in the front
Old 10-12-2003, 09:33 PM
75 BBC Stingray
TTT
Someone who has done this want to chime in?????
I've been searching the archives and am coming up empty...
Old 10-12-2003, 09:46 PM
Guru_4_hire
Cruise-In V Veteran
I think ecklers makes an adapter or at least they used too.
Old 10-12-2003, 10:59 PM
BSeery
BSeery's Avatar
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Using C5 wheels on a C3 (Guru_4_hire)
The adapters you are looking for are from Vette Brakes and Parts, http://www.vettebrakes.com .
Tell them the model and year of car you have and the wheels you want to put on it and they will get you the right adapters.
See signature - 17x8.5's and 17x9.5's.
Old 10-12-2003, 11:10 PM
Glensgages
Glensgages's Avatar
Default Re: Using C5 wheels on a C3 (BSeery)
BSeery, isn't there a forum member named 'jroddvette' (or something like that) who has ZR1 wheels on his C3? I think it's in his sig???
Old 10-12-2003, 11:25 PM
BSeery
BSeery's Avatar
CI 6-7-8 Veteran
Default Re: Using C5 wheels on a C3 (Glensgages)
I don't know.
Old 10-13-2003, 09:20 AM
groovyjay
groovyjay's Avatar
Old 10-13-2003, 09:04 PM
corvettemaster
corvettemaster's Avatar
here's a custom 81 vert with a set of early c5 rims. i love this car! :cool:
[Modified by corvettemaster, 9:04 PM 10/13/2003]
Old 10-13-2003, 10:11 PM
Glensgages
Glensgages's Avatar
Default Re: Using C5 wheels on a C3 (corvettemaster)
I think this C3 was featured in either VETTE or Corvette Fever a few years ago, a body-man on Oklahoma did it.....
I think he tried emulating a C5; note the enlarged wheel-well openings, how he over-sized the rear 1/4-panels (similar to a C5), and 'chopped' the windshield, and rag-top to match the 'speedster' look.
I think it was an '81 or '82, and the drive-train @ that time was bone-stock...
I'm not too-much for wildly modified C3s, but I'll make an exception for this one!!!!!
:thumbs: :chevy :thumbs: :chevy :thumbs: :chevy
Old 10-13-2003, 10:28 PM
corvettemaster
yep same car. it was in Vette magazine. click for larger version:
[Modified by corvettemaster, 10:29 PM 10/13/2003]
Old 10-14-2003, 08:26 AM
75 BBC Stingray
Default Re: Using C5 wheels on a C3 (groovyjay)
groovyjay
That is exactly what I was thinking of. Do you know anything about how they have the wheels attached?
Old 10-15-2003, 02:51 PM
75 BBC Stingray
So much for my master plan. I've searched the web sites for Goodyear, Nitto, Kumho, Cooper, Yokohama, and BF Goodwrich. None of them make the tire size I'm looking for, for the rear tire. I've found few actually make a performance size of 255-50-R17 for the front.
If I don't mind changing the tire Ø from 27" to 26" then the possibilities go up. It looks like even after stepping up to modern wheel sizes, that getting performance tires that are the right size is still problematic...
Old 10-15-2003, 06:24 PM
battsup
battsup's Avatar
Whoa! i was just looking at the pictures for that red 80 convretible and they turned into red x's
Old 10-16-2003, 05:15 AM
groovyjay
groovyjay's Avatar
groovyjay
I can't think anything else than wheel adaptors, VB&P should know what size if you call the up. :cheers:
Old 10-16-2003, 04:24 PM
MN-Brent
MN-Brent's Avatar
If you try 285/40/R18, Dunlop Sport 9000 has this size and you get the magic 27 inch height.
Front= 255/50/R17 on 17 x 8.0 with 4.0 inch BS
Rear= 285/40/R18 on 18 x 9.5 with 4.5 inch BS
You could run the OEM trailing arm with the E-brake bracket moved to the top of the arm and I think you would be good to go.
At this point to only thing stopping me from doing this today is the $$$$.
Brent...
Old 10-16-2003, 11:14 PM
corvettemaster
Default Re: Using C5 wheels on a C3 (battsup)
:lol: that's because i've went over my daily bandwidth on villagephotos.com. this wouldn't happen if my stupid server wasn't down...again! :banghead:
To Using C5 wheels on a C3
Quick Reply: Using C5 wheels on a C3
