what dye to use for dash pad?
im ready to dye my dash and have my doeskin dye ready but i also want to do the black, top part...
all i can find is gloss black and flat black in Krylon Vinyl dye...
shouldnt i use a SEMI flat or SEMI gloss instead...?
what have some of you guys used?
Re: what dye to use for dash pad? (SIGNGUY)
Leatherique products ARE "Simply the Best". They are a bit pricey, but you get what you pay for.
http://www.leatherique.com
"Do not settle for inferior hard lacquer spray paints. This is the one and only, complex co-polymer fomula that others try to imitate. Totally different from Lacquer based paints that dry hard, crack, peel, and have a "plasticy" look to them."
"Send color swatch and specify matte, natural sheen, or high lustre finish. We have many manufactuers swatches on file. If you know the color number, year, make, and model or your automobile, we can match to original manufacture swatches."
Their leather dye also works great on vinyl.
David
[Modified by GATOR454, 9:25 AM 10/10/2003]
David
I have always used SEM vinyl products with great success. They have just the right gloss and hold up real well. They are available in spray can or quart cans. good luck, Craig :chevy
