Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension How-Tos
- How to Replace Tie Rod Ends
Step by step instructions for do-it-yourselfers.
tie rod end removal?
Looked at some past posts, and read a pickle fork could be used to knock out the tie rod end. Has anyone done this with the tie rod still attached to car? Seems like it would bend the dampner or put some major stress on it.
Also the rod that connects to the idler arm, has a slight bend before it attaches to idler. Normal?
Re: tie rod end removal? (Blues77)
To seperate the tie rod end from the spindle remove the nut and use a 3 pound mall and hit the spindle where the tie rod slips into it.:smash: It is a taper fit and a few good whacks will loosen the fit and it will fall right out. Do not hit the tie rod threads though.
Re: tie rod end removal? (Jeff78)
Jeff, I gave it a few good wacks with the sledge but still no budge. I know I could eventually knock it out, but that dampner rod, looks like it could and will bend? I assume your dampner was still attached?
Pickle forks are okay as long as 1) the mount eye is not attached to anything with a bearing (such as the steering gear/pitman arm) because you can ruin the bearing etc, and 2) as long as you are not going to re-use the grease boot (the fork usually rips the boot).
I normally use a small pitman arm puller to remove tie rods... no muss. no fuss.
Last night, I removed the two outer tie rod ends from a Mustang GT with a small hammer just as described above (I'm replacing the rack & pinion) ... they weren't overly tight so they popped right out. Sometimes thay are really tight due to overtightening by a mechanic. In that case, the hammer and/or pickle fork will not work... a puller must be used.
Re: tie rod end removal? (Tom454)
Steve :steering:
Re: tie rod end removal? (stpman)
I had to have a shoulder reconstructed because I thought the pickle fork was the way to go. I now have a set of pullers. Trust me, their much cheaper than surgery and less painfull. :yesnod:
i just loosen the nut on the tie rod, but dont take it off.
While the nut is still on by 2 or 3 threads, hits it with a hammer until the taper breaks.
This way you wont damage the threads.
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: tie rod end removal? (RJR99SS)
It helps alot to hold the side of the maul behind the eye and slam the other side with another hammer. It will distort the eye enough to slip off the taper, two or three whacks is usually all it takes.
Re: tie rod end removal? (Smokehouse69)
I use a pry bar and a hammer. Pry up or down(the other side of the nut) then whack the spindle with a hammer. Works everytime. Most of the time I have to reuse the parts and Not Damage the boots.
:cheers: Larry
:cheers: Larry
This tool from Summit Racing is the bomb: OTC-6297. I'd whacked and banged to the point of tears then a kind soul on this forum recommended it. It cost $49 but is worth it's weight in gold. Used it this morning.
