Help Please 82AC description or pictures
Please tell me on an 82 350 with AC, can you see two ports and two tubes on the evaporator? Where does each of the two tubes connect? Where is the accumulator located? Where is the service port on this car? Is there a service port and a cycle switch port on the evaporator? Can you advise where the wires from the cycling switch connect to on the other end? Where does each of the hoses from the condensor connect to? Where does the hose from the compressor connect to? Where does the wire from the compressor clutch connecton wire to on the other end? Description or pictures would be great. Please someone with an 82 AC help!
