Changed filter in TH400- Not bad...
Cruise-In V Veteran
Cruise-In VI Veteran
Decided to change the filter in the TH400 before I put the BlueL36 away at the end of the month for the winter. Got a brass-screen SPX Filtran filter ($7.53) and cork-and-neoprene gasket ($1.10) along with a case of ATF fluid ($14 at Costco.) Used a flattened cardboard box and an old refrigerator basin pan for overflow. Made a catch pan out of a two-gallon laundry detergent container (cut off side, then when finished draining fluids- oil or ATF- can uncap side to poor into a milk jug to take to recycler.)
My tranny pan does not have a drain plug so I anticipated a messy job. However, wasn't quite as messy as I feared. Did get rid of some of my ratty tee-shirts (wife now happier.) Cleaned the pan with carb cleaner and cleaned the bolts with mineral spirits. Took care to keep exposed tranny clean and let it "drip dry" before I buttoned it up again (15 ft/lbs on bolts.) Did not do the "cooler line flush" to get more fluid out because the ATF I drained was not too discolored. Plus, I wanted to get out and about. Ended up replacing a gallon of ATF. Absolutely no leaks. And because it was a fairly easy job, and cheap, decided to wait until spring to drain the pan and flush from the line. At $10 for parts, will even replace the filter/gasket and pop for new cooler line hoses. Still have plenty of ATF left.
The shifts seem a bit smoother (at least that's what I want to believe) and I feel good knowing that the filter is new. If you haven't changed your tranny filter, do it! Just be aware that your fingers will smell like ATF fluid for the rest of the day no matter how many times you wash your hands.
Re: Changed filter in TH400- Not bad... (bigvette1)
Its not bad but I finally ended up purchasing a tranny pan that has a drain plug on it for the Turbo 400 I have in my 1968 Rally Sport Camaro.
Made things even easier!!!
Re: Changed filter in TH400- Not bad... (James)
Bluel36, What year is yours? I gotta change out the fluid on my 81 (stock automatic) And was wondering how difficult it would be??
